A drawbar fit a SA?
Todd in SE Ohio
03-02-2008 05:56:51
I found a fellow with a U drawbar off of an A at a reasonable price. Will the drawbar from an A fit on my 48 Super A? This is a working tractor and a little modification wouldn't hurt it any.
gene bender
03-02-2008 07:48:33
 Re: A drawbar fit a SA? in reply to Todd in SE Ohio, 03-02-2008 05:56:51
They are different if you are restoring you should get one for the SA. They go reasonable on E-BAY. The one for an A are the money ones.
Lewis
03-02-2008 10:01:54
 Re: A drawbar fit a SA? in reply to gene bender, 03-02-2008 07:48:33
I know this isn't the classifieds, but if anyone needs a drawbar for an Farmall A, let me know.
Actually, it is one of the items on the list I had tried to give away a couple of years ago. Lewis
tn terry t
03-02-2008 06:27:24
 Re: A drawbar fit a SA? in reply to randy hall, 03-02-2008 05:56:51
i took a super a draw bar and put on an A the plates that bolted to the final drives were different i took i/2 " x 4plate and transfered the holes from the A finals to the plate the transfered the draw bar pattern then drilled and welded a pin for the front swivel and just through drilled the back for the back bolt not a big deal and was cheaper than looking for the right plates
