OT: Draft control and the death of the trailer plow
mkirsch
03-03-2008 05:43:40
Something that's always bothered me about draft control is that when the going gets tough, it reduces the depth of the plow. So, instead of breaking up that hard-packed soil, the whole reason for plowing, it just skims over the top of it.
Surely the key is in setting the draft just right, so it doesn't lift too much in hard going or sink the plow too deep in easy going, but still, the whole concept seems counter intuitive.
On a semi-mounted plow, draft control only affects the front, so now you're also plowing at inconsistent depths.
Why then, is draft control "better?" Why did IH's development of effective draft control mean the death of small trailer plows?
Rootsy
03-05-2008 09:23:48
 Re: OT: Draft control and the death of the trailer plow in reply to Re: 460 is a knocking..., 03-03-2008 05:43:40
Pertaining to Fast Hitch draft control, here it is straight from the 460 / 560 Fast Hitch Operator's Manual.
Now my ground at my place is nice black loose dirt with quite a few rock. My M put out 56 HP on the PTO dyno and I can stop it dead with my #70 3-16 if the stop on the cylinder slips and sinks it to the drawbar and over the centerline of the M&W fixed coulters. I have it weighted to 7400# and new 15.5 - 38 Firestones....
Have a 412 4-16 semi-mount bought brand new with my 560 in '63. The ground at my parents is non draining heavy with a lot of clay and extensively tiled for drainage. In years past, especially sugar beet growing years the 560 was weighted in excess of 10000# and sometimes would need the M chained to the front to get it through the soil. If it is any testament to how hard it is, the traction control lever and linkage are off of it because the FH has been broken multiple times where it bolts to the rearend casting and has been patched and welded.
I'll take my 412 on the FH any day over my #70 on the drawbar.
third party image
karl f
03-04-2008 19:28:34
504-2 said: (quoted from post at 20:01:01 03/03/08) I had a Massey service engineer tell me that if everything was set on a 1130 that the front wheels should just float across the ground.
my dad's farming stories from back in the day include the MM UTU's front hovering over the ground on a 4-14 JD pulltype til you pull the rope at the end. and a 3 ft blue flame above the muffler, or is it 4 ft now...
my dad and uncle have never plowed with draft control on. get stuck alot, overheat trannies (the ford 5000), etc.
seems to me every operator manual description of some type of draft system say that the arms will lift slightly in response to conditions and the tendency will be to transfer the load to the rear wheels. if the arms lift the implement so you can see it's lifted and the depth changes, then you are adjusted or set up wrong as it is over correcting. 90% of the 70s/earlier methods/manual quotes and what is encountered on this forum is for 2wd tractors with 70/30% rear favored weight, not 60/40 or 50/50 on an mfwd. and the equipment types we use today are not as simple as moldboard plowing (draft) vs mowers (position only). that leads to another issue; people using draft control too often when position is the correct choice. example: on land semi mounts should be used in position control only. other equipment types are mentioned ad nauseum in operators manuals both for tractors and the implements. in fact, the implement manual is the best resource to guide you whether you should use draft sensing or not. the tractor manual just gives you the basic examples, which may have exceptions because of your implement's design.
some thoughts for you
karl f
Nat 2
03-04-2008 15:50:26
 Re: OT: Draft control and the death of the trailer plow in reply to riverbend, 03-03-2008 05:43:40
Bob, therein lies the rub: You've got a hard spot that could REALLY stand to be busted up, but you can't keep the plow in the ground to bust it up. If you could just drag the plow through that spot, just once, the problem would be solved for a few years at least, right?
I guess that's what a subsoiler is for...
I've also observed that it's not a matter of wheel spin. If anything, the draft pulls up on the plow just BEFORE the wheels start to spin. When the tractor loses traction, the force being applied to the plow drops. The draft sensor sees this as a reduction in load and would tend to drop the plow in deeper.
GordoSD
03-04-2008 07:00:24
 Re: OT: Draft control and the death of the trailer plow in reply to mkirsch, 03-03-2008 05:43:40
Draft control was also an attempt to help build a smoother seedbed. With no draft, if you encounter little hills and valleys, as the rear goes up and down your inplement would go shallow or deep. The draft kept the implement in the ground at the same depth as the longitudinal axis of the tractor changed quickly and often.
It also helped compensate for varying soils. Light loose stuff, one depth setting, when you came to heavysoil, it would come up a little resulting in the same "volume" of soil being turned. This made a smoother field.
You have to think about what plowing problems IH was trying to solve.
The biggest one was very bumpy field when done. My Dad plowed with four Horses! Sometimes five if you were training a colt.
Gordo
mkirsch
03-04-2008 06:14:21
 Re: OT: Draft control and the death of the trailer plow in reply to neblinc, 03-03-2008 05:43:40
I can only conclude that soil type has a lot to do with how well the draft control works.
The action of the 3pt arms is to pull up on the plow in harder going. The REACTION is what seems to be different for different people. Hugh must have some pretty nice ground, for example, to have adequate suction to make the tires squat.
My observations are more in line with others in this thread. When the going gets tough, the plow comes out of the ground.
LA in Wi.
03-04-2008 06:08:00
In the early 1950s we had our own version of draft control when pulling the #8 trailer plow; we plowed in 3rd gear. When we hit a tough spot, we put the tractor in 2nd gear.
And...wonder of all wonders...it still works for me nowadays.
Jack a
03-04-2008 03:20:30
I"m not as familiar with IH but my old WD and D17 work great with a mounted plow using the traction booster system. Plowed right along side others pulling pull-type plows and there wasn"t a noticable difference at all. Pull 4x14 with the D17 and 3x16 with the WD and due to traction booster I can out plow those with pull-types easily. They are really easy to set and all you have to do is adjust so that the traction booster gauge needle runs at a certain spot.
fixerupper
03-03-2008 22:39:42
In the highly variable soils on my farm the draft control on my 1086 has never been asble to keep a plow at a consistant depth across a field. It did it when the tractor was new and it still does to this day. I've put many thousands of hours on the clock plowing with it and I do know how to adjust it. It's been a frustration to me for years.
On the high ground I can pull 5/18's 6MPH and in the low ground she han't hardly pull it at 8" depth, so that's an example of what my farm is like.
When I have the V ripper on I usually have the draft adjustment pretty much all the way ahead, but not all the way, and let the gauge wheels do the majority of the depth control. This lets the draft control pull up a little for traction in the tough stuff but not enough to affect depth, though it can still be a little frustrating saometimes. Jim
Tmonton
03-03-2008 21:00:21
We used one of the Little Genius trailer plow every year and turned a lot of dirt. This one was 2-16's and had that neat trip rope you tied to the back of the seat.
Same thing .. I would hit a hard packed spot of ground and the points would ride up on top only scratching the surface. Even with good points I had the same result.
I got good enough where I could grab the far right lift lever from the seat and throw it all the way up. Trust me the plow will drop but it grabs deep.
With a little practice and knowing where the hard spots were, I could play the depth wheel to hold the plow into the ground pretty good.
I wouldn't recommend doing this by any stretch because it's a bit risky to lean back that far to release and pull this lever while still moving.
Chuck46
03-03-2008 20:25:56
Mkirsch, The draft control on the IH works very well, at the forward end of the height lever is the response speed control. When set properly it will keep a constant load on the tractor and you will seldom notice the action, except if you have heavy gumbo and sand in the same field. Then you can either not use it or adjust the draft lever as the ground changes. I have plowed many thousands of acres with both a 5 bottom Model 70 pull type and a 5 bottom model 700 semi-mounted, it beats me how anybody could have an arguement that one is better than the other. Good luck, Chuck
Tractorfan1
03-03-2008 19:04:20
According to my 806 operators manual, the hitch does raise and lower to keep a constant draft load.
IaGary
03-03-2008 19:10:28
 Re: OT: Draft control and the death of the trailer plow in reply to Tractorfan1, 03-03-2008 19:04:20
Yup when dad got the 856 they told him if wanted to plow the same dept all the time, to throw the draft control lever all the way forward to over ride the draft control and keep the arms from raising.
I was 12 at the time and still remember the service guy setting the plow telling dad that.
Gary
Mark-Mi
03-03-2008 18:35:44
Hugh,if its not raising and lowering the hitch what majic is it doing?
My Dad taught us buy a big enough tractor,leave the draft on heavy and never CHEAT!Mark
Hugh MacKay
03-03-2008 17:29:45
mkirsch: In the fall of 1975, IH dealer delivered a new 5x16 semi mount for me to try behind my 1066. My dad and another senior both adamant trailer plow guys, I knew couldn't resist two things; namely plowing in a cab and a new plow. Both these men were capable of competition plowing and placing in that competition. If you had asked them before the days of IH lower link sencing, they'd have told you 3 point hitch plow made a good counter weight, doing loader work.
I had about 250 acres to plow that fall, I got to plow 5 acres, need I say more, and those old boys would tell you, "Never a trailer plow built that would match that semi-mount on quality plowing and depth control."
Good draft control doesn't lift the plow. I actually did more plowing with that plow behind my 656 with 16.9x38 tires, no chloride, no wheel weights and 10 lbs air in tires. No it doesn't lift the plow, but on that light tractor (light in relation to that plow) you would swear the seat was going out from under you when that draft control activated. One didn't feel that sensation quite as much on 1066, but you could notice it. Quite sophisticated hydraulics, probably that hitch and hydraulics represent 15% of the cost of the new tractor.
Some competitors hitches did as you describe, in fact IH were the first to nail that and get it right. I was at a farm show not long after I bought my plow, got into a discussion with an ag engineer. He said, "IH has made the first real break through on draft control."
Allan In NE
03-03-2008 18:03:20
 Re: OT: Draft control and the death of the trailer plow in reply to Hugh MacKay, 03-03-2008 17:29:45
Please.
Have you ever in your life walked a furrow?
Allan
Hugh MacKay
03-03-2008 18:44:28
 Re: OT: Draft control and the death of the trailer plow in reply to Allan In NE, 03-03-2008 18:03:20
Allan: Your damn right I have, have you?
IaGary
03-03-2008 17:52:05
Are you sure about that non lift thing Hugh?
I would swear that when mine activates in the tuff spots that I can see those arms come up.
Gary
Hugh MacKay
03-03-2008 18:42:01
 Re: OT: Draft control and the death of the trailer plow in reply to IaGary, 03-03-2008 17:52:05
Gary: We checked plow depths many times and could see little difference. You walk alongside when someone is plowing, and I noticed this especially on my 656 with the 5x16 plow, it was rear of tractor flattening those tires out, causing the rockshaft to appear it is lifting. That is what it's designed to do, put as much weight on tractor back wheels as full chloride and wheel weights together.
It's very noticable when the tractor is just a bit on the light side for the plow. I hardly noticed it when plowing with 1066 on that same 5x16 plow, but then the 1066 probably needed very little extra weight.
I remember my neighbor having a 200 with a 2x14 plow, be in the late 50s, chloride and one set of wheel weights. He plowed successfully with it for a few years. One day the Massey dealer drove into field with 135 and 3x12 plow, no weight. He told the farmer he could put his MF plow in ground, tow 200 and it's plow plowing behind, esentially he was going to pull 5 bottoms with 135. He soon gathered a bit of audience. He pulled the 5 bottoms, but not more than 4-5" deep. One of the farmers in the audience suggested he come and hitch 135 onto his 5 bottom Cockshutt trailer plow. It didn't happen, however Massey did have a device for use with a trailer plow. Much like a 3 point boom pole, hinged for turning and a chain to front of plow. Massey could use their draft control on a trailer plow. I don't know how well it worked.
ex farmall
03-04-2008 18:39:49
 Re: OT: Draft control and the death of the trailer plow in reply to Hugh MacKay, 03-03-2008 18:42:01
you pull 5-16 with a 656 and gary pulls 6-16 with a front wheel assist mx 200 ?
Allan In NE
03-05-2008 03:41:42
 Re: OT: Draft control and the death of the trailer plow in reply to ex farmall, 03-04-2008 18:39:49
The grandiose award? :>)
Allan
Hugh MacKay
03-05-2008 03:37:37
ex farmall: There are vast differences in soils across North America, and it does one good to plow away from home ocasionally. I had some of the easiest plowing known anywhere. To give you a bit of history, my dad started farming in 1942 with a W4 and 2x14, No.8 plow, drainage was not the best in those days. He certainly enjoyed the bigger wheels when he traded for an H in 51.
After that drainage improved greatly and by the end of the 50s we were plowing with Farmall 130 and 2x12 fast hitch plow, or Farmall 300 pulling 3x16, No 60 trailer plow. In the mid 60 we moved to a 4x16, No.60 behind a 560. In 1975, I purchased a 5x16, No.510 semi mount to use behind 1066. The very next year I dualed the 1066 and had other heavy work for 1066. I looked at reducing that 5 bottom plow to 4 for use behind 656, we had it backed into shop ready to make the change. I said to Mike (guy who worked for me, "I don't want to loosen all those bolts, go up on that big hill behind the barn and if you can plow 8" deep on that hill we can pull that plow anywhere on the farm." He did, and 3-4 hours later he had the whole hill plowed. We never did reduce the plow, and never plowed with 1066 again. 656 lugged it along at 4 mph, and remember a 5x16 plow at 4mph will plow more land per day than a 4x16 plow at 5mph, less time spent on the headlands. I might add 1066 once snapped a trip bottom even though it tripped, never had that happen with plow behind 656. Through the 70s and 80s most of my neighbors were pulling 5x16 plows with 60-80 hp, that's all it took in that country. I even had one neighbor pull a 5x16 trailer plow with a Cockshutt 570.
Just to give reasoning why folks should plow away from home. I've had the opportunity to plow in heavy clays of SW Ontario with my Farmall 130 and 2x12 plow. there are spots in this clay very hard, a much harder sub soil that ocasionally comes into plow depth. If I'm plowing in 2nd gear with 130, about 4 mph with 12.4x24 tires, and I strike some of this real heavy clay, it will kill the 130 before I can hit the clutch. Guys who have plowed this soil for years, tell me 4x14 plow was the limit with a 656, and your happy to have TA, and kept your left hand very close to that TA lever. I've also plowed some very light sandy loam with 130, figured this stuff would be close to back home, learned something new again, one spin of a wheel and your axle deep. Now don't jump to conclusions about my opinion on soil quality, some of those heavy soils may be hard to plow, but they hang onto moisture great in a dry year.
Gary may have a bit of overkill with his 200 hp on 6 bottoms, he also may not have overkill. We all know he is in the state of Iowa, some of the most productive land in North America regardless of the weather or the season as in dry or wet.
Allan In NE
03-05-2008 04:23:10
 Re: OT: Draft control and the death of the trailer plow in reply to Hugh MacKay, 03-05-2008 03:37:37
I dunno, must be one heck of a lot of difference then.
My hired man had a 5020 with a 5-16 and it was all that tractor wanted.
"Here" 3-14s on a 656 will just work the snot out of the tractor in 2nd.
Allan
Hugh MacKay
03-05-2008 08:57:12
 Re: OT: Draft control and the death of the trailer plow in reply to Allan In NE, 03-05-2008 04:23:10
Allan: I know your a bit skeptical about all this, however your no more skeptical than my dad and his friends were back in the mid 1950s when the then new MF dealer traveled the countryside with a MF 35 and a 3 bottom, 3point hitch plow on his trailer. IH probably had about 60% of the market in our area back then with Cockshutt, Oliver, MH, Ford and Deere dividing the rest.
We were small farmers back then, just overcoming a drainage problem due to high water table. That first plowing on old meadow sod was hard. Most farmers plowed 20-30 acres with Farmall H, Cockshutt 30, Oliver 66, etc. and 2x14 trailer plow. Most folks just laughed at the MF guy, wouldn't even let him unload the 35. The ocasional guy with a SC or Cockshutt 20 let him in. He did plow 3 bottoms with that 35 and folks soon got a lot of respect for 3 point hitch and draft control. It wasn't hard for us to take every advantage of the 3 point hitch on a 656 or a Oliver 1650. We ran em light with big rubber, and let weight transfer do it's job.
Fields that my dad excerised care where he went with team and mower in 1940, we crossed with semi's by 1960. It plowed easy, sandy loam about 8' deep, then the purest kind of gravel, with a perminant water table at gravel level. It was hungry land, but man would it turn out dry matter yields of alfalfa. Unless it was fixed N one may as well have had a seive.
Allan In NE
03-05-2008 10:36:40
 Re: OT: Draft control and the death of the trailer plow in reply to Hugh MacKay, 03-05-2008 08:57:12
I guess if you only have that much topsoil I can now see where you would analyze the operation of the draft the way you do.
When that “suck” first takes a bite, it does tend to “compress” the tires just a bit. I would imagine this was the level you were at in your plowing, etc. and this is how you read it.
However, “here” after the suck is struck that implement is pulling down so darned hard on the tractor, wheel weights are hardly even needed. Keeping in mind that I use fully mounted plows, can tell you that I have never, ever seen a wheel slip while plowing unless it was from just plain old mud; it’ll bog/kill the tractor first.
Have spent many a year watching that draft physically lift the implement out of the ground. ‘Course like I say, an 8” furrow would be a “skip” to me.
Hooked on to the tumble plow one time with both a 2010JD and also with an H. Think those old plows were what? 2-12s? Anyway, neither tractor would pull the plow past the suck. When the 2-bottom plow hit running depth ('bout 3 feet), it just flat stopped both of those little guys.
Guess that’s why I’m always so skeptical when I hear of someone “plowing with an H”. :>)
Allan
IaGary
03-03-2008 18:54:13
third party image
third party image
Hugh the tires do not flex on this tractor, the hitch comes up.
As much as you want to believe it doesn't it does and I can film it if you want.
Did you ever notice in those tuff spots the front would tend to come up as the draft control was working but as the plow loses the suction and comes up the front would come back down.
That is one of the reasons for the draft control is to keep the front on the ground.
Even with a full rack on the front 1086 the front would come up till the plow came out of the ground.
The first picture is 19,000 lbs and 175 hp on 6-16's and the hitch will come up.
Gary
BOBM25
03-04-2008 14:05:43
 Re: OT: Draft control and the death of the trailer plow in reply to IaGary, 03-03-2008 18:54:13
I'm goning to side with you Gary. If you are plowing at constant depth all the way across a field, N to S and E to W, then 1 of 2 things is happening. You are a very wealthy man because you farm good, even, consistant, productive soil or you are not paying close enough attention to your implement. Draft control does raise the lift arms. What else could it or would it do? When you hit a tough patch of dirt, the plow pulls hard, right? I don't think anyone will argue this. When this happens and you have a green tractor, the tractor dies. If you have IH power, you spin your wheels. Well spinning your wheels doesn't get you anywhere, so the tractor lifts the front of the plow. How fast it lifts depends on how you have the draft set. Every action has an equal and opposite re-action. Sir Issac Newton told me this back in HS. Therefore, the force used to lift the plow is first transferred down on the tractor tires. Hopefully this extra little bit of force will give enough added traction to enable the tires to hold enough to pull through the tough spot. The tires can only be compressed so far, however. This depends on psi, tire size, etc. When no more force can be applied down on the tires, the plow will start to raise. Yes, you don't maintain consistent depth, but what else can you do? You have to keep moving. You can't hardly plow some of your field with a 5 bottom, then switch to a 4 to get through the tough spots. I think Hugh farms some pretty nice soil where he's at. I know around here its not uncommon for an 80 acre farm to have 4 different soil types. We have a yield moniter in our combine. We have spots where we can get 200 bpu corn, and other spots in the same field in the same year where we get 100. Same seed and chemical and fertilizer applied to the entire field. Its just that the soil is that much tougher. You won't get a bumper crop off of every acre.
Hugh MacKay
03-04-2008 02:26:42
Gary: No need to film that, I can make the tractor do that if I set the draft control that heavy.
Allan In NE
03-03-2008 18:58:31
Oh no Gary,
You're totally wrong in this respect.
I really think you need to get out more and see the rest of the world. Not everything is as it appears in Iowa ya know.
Allan
Hugh MacKay
03-04-2008 12:54:39
 Re: OT: Draft control and the death of the trailer plow in reply to Allan In NE, 03-03-2008 18:58:31
Allan: I don't ever recall suggesting the same about Gary, as I did you.
Allan In NE
03-03-2008 16:12:06
Yep,
It will do that if ya skim along the top at 7 or 8" deep like a disc.
Allan
Steven f/AZ
03-03-2008 14:21:06
I would think draft control was useful for those that were at the limit as far as what they could pull and wanted to plow as deep as they could... but I don't know much about draft control or plowing...
I just know that a 4-16 plow in old sod was enough to make our 1086 bellar, but Dad was going pretty fast... LOL
495man
03-03-2008 14:07:02
 Re: OT: Draft control and the death of the trailer plow in reply to Mike L, 03-03-2008 05:43:40
Hence "position control" on most three point hitch set ups for when you don't want the draft control taking effect
504-2
03-03-2008 19:01:01
 Re: OT: Draft control and the death of the trailer plow in reply to 495man, 03-03-2008 14:07:02
You have to think of the draft control as putting more weight on the rear wheels not lifting the plow, and the speed that it works is so fast the plow can`t come up before it is already going down. I had a Massey service engineer tell me that if everything was set on a 1130 that the front wheels should just float across the ground.
