I-6 tires
sven
03-03-2008 16:44:13
I am looking for a useable set of tires for the slit rims on the rear of an international i-6. I was wondering if anyone knows of the different sizes that will fit the rear of the tractor, in either ag or industrial tread.
Thanks
Haas
03-03-2008 18:29:08
 Re: I-6 tires in reply to sven, 03-03-2008 16:44:13
My I-6 has 13.6 x 24 agricultural tires on it. If you want industrial tires, I suppose you can get those also in that size, but they will likely cost more than the ag tires. The problem is finding a shop that will mount tires on the split rims. Shops these days don't want to fool with the split rims.
Joe H.
03-03-2008 17:08:34
The orignal tires were a 13.00*24 or 14.00*24 simmiler to what a motor grader sports but just the same a 13-6-24 or or 14-9-24 ag tire would work I currently dont have a matched set but u might contact your local county road department or a construcion co in your area that might have a used set good luck!
