SA TC pressure regulator valve seat...
P and R Pete
03-03-2008 16:54:57
...is out.
And the tool that did it.
third party image
Tight thing, though. I had to put a board against the front end, lean against the block, and reach over and pull the tool toward me to crack it loose.
Even then, (with it's own O-ring), it took some 'convincing' to talk it out of the bore.
Hey Greg, too bad you don't live in the next town. I'd run 'er over!
tractorsam
03-03-2008 17:03:04
 Re: SA TC pressure regulator valve seat... in reply to P and R Pete, 03-03-2008 16:54:57
That looks darn good to me.
Pity they changed them at some point. Mine uses a bushing that surrounds the valve like the check valves have. The catch is it's larger and so I need a larger piece of hose and bolt to remove it (I hope). Wouldn't be life if it wasn't interesting. tractorsam
riverbend
03-04-2008 05:35:41
 Re: SA TC pressure regulator valve seat... in reply to tractorsam, 03-03-2008 17:03:04
I used the same bolt, a 5/16" washer under the head, and wrapped a strip of inner tube around 3/8 fuel line. A little cut and try will get the strip the right length so it just fits in the bushing. A wrap of electrical tape keeps it in place.
Greg
tractorsam
03-04-2008 14:46:26
 Re: SA TC pressure regulator valve seat... in reply to riverbend, 03-04-2008 05:35:41
I've got some other sizes of tube now so I'll have to give it a go later on. I do have some old inner tubes around so that is always a possibility. tractorsam
