Finally: Got the Loader Installed!!!
Charles Todd
03-03-2008 17:14:41
Finally got all of my parts together and installed the Koyker 220 on the Farmall 504. They make a good pair.
The Beginning
third party image
Friday night, It got dark...
third party image
I questioned the little one's abilities here...
third party image
Getting there
third party image
SIZE MATTERS
third party image
It is verrry dark Saturday night,
third party image
Sunday finishing up
third party image
third party image
third party image
third party image
third party image
I need to build my shop, doing this work outside stinks...
Thank you for your help with my questions.
Steven f/AZ
03-05-2008 06:37:29
 Re: Finally: Got the Loader Installed!!! in reply to Charles Todd, 03-03-2008 17:14:41
Loader looks good... it looks as though the front end needs some rearward bracing before you start heavy lifting, though.
Ran a 504 for a couple years for a friend, wonderful tractor for light jobs like mowing, raking, tilling, etc. Easy on fuel and reasonably comfortable to ride on for days on end.
I like your pic about size matters... but if size truly matters, you need one of these:
Link
Link
LOL :roll:
Charles Todd
03-05-2008 18:57:16
 Re: Finally: Got the Loader Installed!!! in reply to Steven f/AZ, 03-05-2008 06:37:29
The next move after securing all of the small hydraulic leaks is to rebuild the axle mount and to brace the wishbone further back. The front axle is a mess, but for the price of $0.00 for the tractor, I can work with it!
mkirsch
03-05-2008 05:21:55
 Re: Finally: Got the Loader Installed!!! in reply to Re: 460 is a knocking..., 03-03-2008 17:14:41
Moving the wheels out on the axles will only add a marginal amount of stability, but it will make plowing snow and using the loader along side of things more difficult with the wheels set wider than the bucket.
Loading the tires will give you the most bang for your buck with regards to stability.
Charles Todd
03-05-2008 18:53:55
 Re: Finally: Got the Loader Installed!!! in reply to mkirsch, 03-05-2008 05:21:55
We do not get much snow in Louisiana (about 1" in 10 years!) and I bale hay with this rig and the axles are set at about 6' 6" centerline.
The tires are loaded to the gills and I am searching for rear wheel weights localy.
Thanks guys, I have recieved lots of good info here.
Charles
Harry klever
03-04-2008 19:43:53
Looks good, i had a k-5 on my 806, never had a problem, i bought it new in 1975
Charles Todd
03-04-2008 19:17:42
 Re: PICTURES INCLUDED in reply to Charles Todd, 03-03-2008 17:14:41
Forgot to mention I had pictures...
hillbillyOH
03-04-2008 05:21:49
That's a very nice loader! Good work on the plumbing, too.
Randy in NE
03-04-2008 05:15:46
One thing you might think about is moving the wheels out on the axles to give you a wider stance for when you have the loader way up high. Unless there is a need to have them moved all of the way in. Just be careful with the loader lifted high. There is a lot of weight up there and a lot of leverage for tipping it over. Remember. Safety! Safefy! Safety!
IaGary
03-03-2008 17:31:27
Looks like it should do the job.
Gary
