450 Brakes
Chris450
03-03-2008 17:40:36
The left brake works fine but the right brake seems to grab. It is either all or nothing. Any ideas?
hary klever
03-04-2008 19:37:40
 Re: 450 Brakes in reply to Chris450, 03-03-2008 17:40:36
Well you have to take it apart, chances are you are not going to believe how much dirt and brake lining grindings , are in there, I wear a mask and rubber gloves,, clean and or repair,, and get a new boot, to keep dirt from getting up in there if u can find one, !!!
Brownie450
03-04-2008 03:34:24
Take the 5 bolts out of the brake housing & remove it & inspect the parts to see what the problem is. Take the 3 springs off of the actuating plates to clean & inspect them also. Also, take the actuating bolt out of the front of the brake unit before removing,
r4etired
03-03-2008 18:04:07
Sounds like the brake disc is catching in a groove in the brake shaft,sometimes you can get by with smoothing it with a file,sometimes takes a new brake shaft.
