Super A Final Drive and Woods Mower Bracket
eye4iron
03-03-2008 23:01:25
I have a Super A that has a woods belly mower on it. When mounted, the brakets that bolt on to the final drive housings cover up the fill plugs for the final drive. I have to remove the brackets to check the oil level in the final drives. Has any one ever cut holes in the brackets so it can be checked without dropping the woods brakets ?
Haas
03-04-2008 06:51:03
 Re: Super A Final Drive and Woods Mower Bracket in reply to eye4iron, 03-03-2008 23:01:25
I have seen this done before. You need to accurately layout to cut the holes and don't cut them any larger than necessary. The one I am aware of had a machine shop cut the holes. However, I believe it could easily be done on a drill press with a metal cutting (high speed steel) hole saw.
gene bender
03-04-2008 00:08:59
Good question but if the pan is full of 90wt and there are no leaks there realy isnt any reason to check the level is there.
eye4iron
03-04-2008 06:30:19
 Re: Super A Final Drive and Woods Mower Bracket in reply to gene bender, 03-04-2008 00:08:59
Yes Gene you are correct. The oil should stay in the pans and if there is a leak at the out drive or a pan gasket you should notice it. I have however heard of the pans occasionally getting dented in on the bottom and then the gear rubs a small hole in the pan later on. It is possible to loose your fluid while mowing and not know it. I thought that an easy access to the fill plug would be a good idea but I didn't know if the 3/4 inch hole would hurt the Woods bracket structurally.
