806 or 856
RIVIR
03-04-2008 04:06:28
which tractor the 806 or 856 should i put a front end loader on ,the gear shift is a little different from each other.
RIVIR
03-04-2008 16:57:16
 Re: 806 or 856 in reply to RIVIR, 03-04-2008 04:06:28
856 it is then thanks for the replys- RIVIR
Steven f/AZ
03-04-2008 06:46:29
The 56 series shifting is much better for loader work... we used 2nd gear and it's an easy flip from High to Reverse on our 1256 we had.
third party image
You can also retro-fit the 56 series shifting onto the 806...
856
03-04-2008 06:29:16
I'd go with the 856 also.
IaGary
03-04-2008 04:34:06
Doesn't the 856 shift a little better than the 806?
Ours did. So for that reason I would put it on the 856.
There's a lot of shifting going on with a loader tractor. It will make your life easier.
Gary
