H Battery box bolts.
GordoSD
03-04-2008 15:14:01
I had to order four of those special square head bolts that fit inside the batt box., from Fastenal I got the 1/2 inch because the heads are perfect for the grooves. So I have two left over. Who needs a pair of these? Gordo
WOEII
03-06-2008 18:58:11
 Re: H Battery box bolts. in reply to GordoSD, 03-04-2008 15:14:01
Bolts still need a home? :D
Mike CA
03-05-2008 16:32:55
You never know! I could get laughed right out of a parade if I don't have the correct bolts!
And what will the children think during the hay ride???
I'll check the junk yard! :lol: (That really wasn't a joke. Yes, I'm that pathetic.)
Mike CA
03-04-2008 23:18:15
 Re: H Battery box bolts. in reply to Re: 460 is a knocking..., 03-04-2008 15:14:01
GordoSD said: (quoted from post at 21:27:38 03/04/08) OK Mike, And I have a generator bracket, Blasted, epoxy primered and painted. Spare. Do you need that?
Gordo
Yeah, that would be great! You wouldn't have the dot bolts for it, would you?
GordoSD
03-05-2008 05:45:59
 Re: H Battery box bolts. in reply to Mike CA, 03-04-2008 23:18:15
No dot heads. I toss those rusty, corrode, pitted, overstressed, things in holes when I plant trees. No one is going to pull your hood, get a flashlight and look up under your generator for correct bolts. Maybe the frame rail bolts, and tranny cover? WHo do you think is judging these things. Leave those bolt worries to the 500,000 dollar muscle cars. You're working on something that MIGHT bring top dollar of four thousand. Shoot me your snail mail address, email is open
Gordo
GordoSD
03-05-2008 05:45:58
Gordo
Mike CA
03-04-2008 15:33:10
GordoSD said: I had to order four of those special square head bolts that fit inside the batt box., from Fastenal I got the 1/2 inch because the heads are perfect for the grooves.
Gordo
I just got a battery box. I haven't had time to look and figure the thing out yet, but it doesn't have any hardware. So if they are what I need, then I'd be happy to have them!
GordoSD
03-04-2008 20:27:38
 Re: H Battery box bolts. in reply to Mike CA, 03-04-2008 15:33:10
Gordo
