424 rear main bearing
jfloyd
03-05-2008 09:03:48
There is a little plate that blocks access to the rear main bearing bolts. Does anyone know how this comes out before I pry too hard on it? I"m worried that it may bolt from the flywheel side and the tractor would have to be broken to do this and to change the rear seal. Also, if anyone has the manual I need all the torque specs and if to know there is a sequence for tightening the head bolts. Thanks
Bob
03-05-2008 10:34:04
 Re: 424 rear main bearing in reply to jfloyd, 03-05-2008 09:03:48
Third Party Image
(GAS)
Third Party Image
(DIESEL)
jfloyd
03-05-2008 10:49:13
 Re: 424 rear main bearing in reply to Bob, 03-05-2008 10:34:04
Gas
The two links or images don't load. Might just be me.
Bob
03-05-2008 10:58:37
 Re: 424 rear main bearing in reply to jfloyd, 03-05-2008 10:49:13
Does this illustration come up for you?
Third Party Image
The little bottom plate that's in your way is bolted to the rear oil seal retainer, with bolts entering from the rear.
jfloyd
03-05-2008 11:12:43
 Re: 424 rear main bearing in reply to Bob, 03-05-2008 10:58:37
Yeah, that helps a lot. It looks like to me you can't change the rear main without breaking the tractor. Thanks for the fast reply and help.
