D Slater - Cam Specs
FarmerSid
03-05-2008 09:05:42
D Slater. A little birdie told me you are the man to ask for IH information. I was wondering if you would be so kind to give me the stock cam specs for a Farmall 300 gas and 504 gas. I would like to compare the two. I appreciate any and all help you could give.
Cheers!
Sid
FarmerSid
03-06-2008 04:32:56
 Re: D Slater - Cam Specs in reply to FarmerSid, 03-05-2008 09:05:42
Thanks for getting back to me Slater. I'd appreciate any info you dig up. Would like to compare the two.
Cheers!
Sid
D Slater
03-05-2008 14:36:13
Sorry someone has overrated me. Dont think I have that information on a 504. Do have on the 300 and if I find it will post. Trouble is remembering where to find it since I don't have things organized to good. Since the memory is going downhill that don't work very good. Poster asked about cams a few days ago. Thought I knew right where the information was, but took me almost 3 hours to find. You can try on the pulling board, think some pullers have cams ground to the 504 specs, and may have a quick answer. Luck
