Final drive reassembly question
Ray Pell
03-05-2008 16:01:10
On an model A right side final drive, when re-assembling, is it better to attach the diff shaft housing to the trans case first then the final drive, or attach the final drive to the diff case than to the trans case? Thanks Ray
gene bender
03-05-2008 17:28:58
 Re: Final drive reassembly question in reply to Ray Pell, 03-05-2008 16:01:10
You can do it either way. Depends on your shop and the tools you have to work with smooth floor ,cherry picker and the list can go.
ScottyHOMEy
03-05-2008 18:43:55
 Re: Final drive reassembly question in reply to gene bender, 03-05-2008 17:28:58
Good point, Gene.
It's been a while since I was at this point, and I think I was just workin' backwards from pullin' it out that way. So it's all a little foggy, but I think I decided at the time that the retaining ring holding the shaft in on the outside might have been a factor.
I'm thinkin' too, that if I'd fitted the shaft and slipped the housing over it, I'd have been at a loss for liftin' the final up to fit it onto that setup.
As you say, all depends on what you've got fer a shop, etc...
'Course (you can see from the picture)I was workin' in less than ideal conditions. I had to run the left wheels of that trailer up on blocks to get a level workin' surface.
Ray Pell
03-05-2008 16:44:33
Thanks a picture is worth a thousand words!
ScottyHOMEy
03-05-2008 16:46:38
 Re: Final drive reassembly question in reply to Ray Pell, 03-05-2008 16:44:33
Yer welcome!
ScottyHOMEy
03-05-2008 16:34:44
 Here ya go in reply to Ray Pell, 03-05-2008 16:01:10
third party image
This is from my BN, but it's the same setup as your A.
ScottyHOMEy
03-05-2008 16:30:38
The latter.
I'm bootin' up another computer so I can send a pic of mine in a coupla minutes.
