460 with 301 gas motor
Kevin Bonwell
03-05-2008 16:17:38
I have a 460 puller with a stock 301 motor I have just bought it and won't pull it until April. If I want to get more HP how do I do it.
Head work, bore it, stroke it, what. Please advise I'm pretty much a rookie. Really thank anyone for the help.
mkirsch
03-06-2008 05:38:31
 Re: 460 with 301 gas motor in reply to Re: 460 is a knocking..., 03-05-2008 16:17:38
Kevin, there's a whole forum dedicated to pulling on this site you might want to check out.
AFAIK, the C301 is a "parent bore" engine, meaning it has no sleeves, and that block is pretty well bored out to its limits at that displacement. The only way to get more cubes and still be able to rebuild the engine once or twice is to make it a stroker, if you can find the crank.
Frankly, you're going to have enough trouble getting what horsepower you do have now to the ground in an effective manner... I'd work on the traction part and run it a while to see what it needs before tearing it down.
Kevin Bonwell
03-06-2008 07:33:57
 Re: 460 with 301 gas motor in reply to mkirsch, 03-06-2008 05:38:31
mkirsch,
Thanks for the info. Any tips on how to get the power I have to the ground.
Twl
03-05-2008 18:12:23
 Re: 460 with 301 gas motor in reply to Kevin Bonwell, 03-05-2008 16:17:38
Should do good enough in 3mph class.What weight class and speed limit are you pulling?
Kevin Bonwell
03-06-2008 04:21:11
 Re: 460 with 301 gas motor in reply to Twl, 03-05-2008 18:12:23
Pulling in 4500 thru 6500 class 3mph
