H Front Axle
neblinc
03-06-2008 05:46:39
Is this repairable or is it anything to worry about? The bearings did come off over that gouge with a little tapping.
Added more pics to my website also.
Randy
third party image
tn terry t
03-07-2008 12:45:51
 Re: H Front Axle in reply to neblinc, 03-06-2008 05:46:39
kinda looks like at one time it may have seized up and maybe someone might have got a little close with a hot wrench spliting the race off. dunno
clean'er up and slap'er back together
GordoSD
03-07-2008 09:12:46
Randy, I've got some new and used bearings for a front left over. Would send them to you cheap!
email is open.
Gordo
GordoSD
03-07-2008 09:12:04
email is open.
Gordo
tom windsor
03-06-2008 19:10:14
Looks to me that this was caused by a bad bearing in the first place. If the bearing slides on there confortably without any slop around, I think that the 60 year estimate would be good. Was the old bearing frozen up?
tw
GordoSD
03-06-2008 14:57:05
Axle is OK but your dust cover and seal are toast.
Gordo
Andy Motteberg
03-06-2008 12:28:07
If the bearings fit on there okay, it should be fine.
Steven f/AZ
03-06-2008 07:27:39
I usually put a nick in the shaft to keep the bearing race from turning on the shaft. I wouldn't worry about it, unless you've modified your H to go 60 miles an hour... :lol:
Owen Aaland
03-07-2008 05:20:58
 Re: H Front Axle in reply to Steven f/AZ, 03-06-2008 07:27:39
The bearing should be a slip fit on the spindle, not a press fit. They are designed to be able to turn slightly on the spindle so that the wear can be distributed more evenly on the inner race over the life of the bearing. If they did not turn they would wear out sooner due to loading on the bottom side.
Wayne in MN
03-06-2008 05:50:07
If the bearing will slide over the nick in the shaft, there should not be a problem.
Allan In NE
03-06-2008 05:49:21
You bet!
Dress 'er up just a tad and slide those new races right on there. Probably will last another 60 years or so. :>)
Allan
