Order Farmall Cub Parts Online
cub fan assembly
ih10020
03-06-2008 10:33:51
oil leaks out of cub fan assembly-is this a re-
pairable unit or do i need to look for another one? thanks & keep it red.
john *.?-!.* cub owner
03-06-2008 13:37:38
 Re: cub fan assembly in reply to ih10020, 03-06-2008 10:33:51
You are probably overfilling it. there is no seal on the shaft. turn the fan so the fill screw is to the right, viewed form the rear, then fill it with oil. Next, turn the screw hole down and let it drain. There is a standpipe inside to set the oil level. Next, turn it around and replace the screw. All of these instructions are in the owners manual.
Andy Motteberg
03-06-2008 12:17:52
You could buy a new one or find a good used one.
Jim Becker
03-06-2008 11:56:29
Sometimes they just leak becasue of being over filled.
Andrew Z
03-06-2008 10:50:49
Iv had fans go bad the shafts were out and i even had one seize up on me. just get a new aftermarket one, they look really close to the OE. you could always get a used one too, but then you take a chance that its not good to.
here is a link to aftermarket one on this site,
