1486 3 point adjustment
Lee in Iowa
03-06-2008 20:49:14
Does anybody know how to adjust the 3 point on a 1486 so it comes as high as it did when it was new. When it was new the upper 3 point arms came up so they were very close to the fuel tank. Now they're down a ways. I guess they are supposed to measure 39 3/16 inches from the pin at the front of the lower arm to the pin at back of the upper arm when its raised clear up, mine only measures 37 1/2. Need it to load round bales on a bale trailer so I need all the height I can get. Thanks Lee
dogleg
03-08-2008 20:57:34
 Re: 1486 3 point adjustment in reply to Lee in Iowa, 03-06-2008 20:49:14
You may have already tried this but I remember on our 186 hydro there were two levers for the 3 point; the actual up and down and then there was a load adjustment lever. I remember playing around with the load adjustment lever and the arms would pull up higher with the up and down lever all the way up. Been a long time since I dealt with it but worth a try.
Lee in Iowa
03-08-2008 06:59:13
Thanks for the replies guys. The indexing arrows are lined up thats never been apart. The bottom of the control lever seems tight. I got a hold of a ihc chassis manual and it talks about an adjustmnt but I couldn't figure out where it was so I looked at my IT 856 book and it talked about an adjustment behind the 3rd link bracket. I tried adjusting that, but it made no difference. so now I don't know what to do, that extra couple inches would get me just enough to work. Lee
Brent1086
03-07-2008 16:08:18
Two other things to check. I had this problem on my 1086. The bushing in the shaft on the bottom of the contol lever was worn out. There is a slot on the control rod that can be adjusted also.
Allan In NE
03-07-2008 08:19:18
Are the indexing arrows lined up?
Maybe someone had 'er down for repairs and didn't get it back together right?
Allan
Lee in Iowa
03-07-2008 18:00:21
 Re: 1486 3 point adjustment in reply to Allan In NE, 03-07-2008 08:19:18
I guess I don't know about the indexing arrows where are they located. Thanks Lee
Brent1086
03-07-2008 18:39:37
 Re: 1486 3 point adjustment in reply to Lee in Iowa, 03-07-2008 18:00:21
The index arrows are on the splined end of the rockshaft and on the rockshaft arms, there might be two arrows on the rockshaft use the upper one.
