3 point arm adjuster stuck
Jeef
03-07-2008 10:12:32
As you are likely aware because of my mass of questions I have a 574 that has had some minor issues that I have been fixing.
The 3 point arm leveler on the right side of the tractor tha that has a crank on it is locked up tight. I have soaked this for weeks with penatrating fluid with no luck. It seems to be stuck solid. Everything else on this tractor has started to work but this one.
Any Ideas?
I am about ready to take the hole thing off and soak it in penatrant.
Jeef
03-07-2008 19:17:52
 Re: 3 point arm adjuster stuck in reply to Jeef, 03-07-2008 10:12:32
This is the one with the gear in the top. Are we talking about the same thing? Being mostly cast I am a bit concerned about heat :O
But if that is the solution then so be it.
RustyFarmall
03-07-2008 10:45:00
New parts are available for the three point on that tractor. Do as Mike said with the heat first. If that don't get it, send me an email.
mike french
03-07-2008 10:38:21
heat is the only thing that will help, rosebud on a torch works good.
