Identification on farmall 100
Glynn Moore
03-07-2008 17:25:23
Hugh Mac or other guys--I'm working on a farmall
100-(engine work)-A guy in the family I bought it from said an engine from a 140 had been put in the tractor @ some time in the past--While removing the head I see it has the long stud bolts with nuts rather than head bolts as my 140 does--Any way ofKnowing??--Hugh, how can I contact you???
Hugh MacKay
03-07-2008 18:17:32
 Re: Identification on farmall 100 in reply to Glynn Moore, 03-07-2008 17:25:23
Glynn: On classic view go to bottom right of expanded thread, click on "send mail".
The correct block part numbers are; for a 100 is 354898 R2 or R3, 130 is 366204 R1 and 140 is 367825 R1, R2 or R3.
couv
03-11-2008 04:53:29
 Re: Identification on farmall 100 in reply to Hugh MacKay, 03-07-2008 18:17:32
I am looking for a replacement block for a 100. Mine is a 354898R3.
People are offering to sell me all kinds of casting number blocks. Prices are all over the board.
What are the pitfalls & benefits of changing to another casting number block ?
Mine is an "R3" that had a dipstick hole plugged with a cork plug, yet it had the "two faucet" oil pan.
Center main journal had spun the bearing over the years. Rebuilder says he can put a spacer block in the bad journal, re-line bore it, and put it back togethr correctly -- however adds that this would add maybe $700 in machining costs.
any adivse ?
Hugh MacKay
03-11-2008 06:19:09
 Re: Identification on farmall 100 in reply to couv, 03-11-2008 04:53:29
Couv: You can use any of the blocks I listed in my previous post, however your pistons and sleeves will only fit the 354898 R1, R2 or R3 block. Bear in mind the R1 will have come from a SA or SC with no dip stick hole unless someone has drilled it.
You can use the 130 or 140 block, however you'll have to match pistons and sleeves for those blocks. There is another snag with a 140 block, 140 used an automotive type water pump on the fan shaft. I don't think you can change that to your pump, hole in block not drilled right for your system. I'm also not certain a 140 fan will match up with your rad and shroud. I have both 130 and 140 but I've never had them apart at same time. Near as I can tell that one may cause you grief.
