hows it work?
tn terry t
03-07-2008 19:51:50
Link can ya tell me how it supposed to work the handle moves the rod that goes to the front of the hitch but nuthin else seems to move as it is the cylinder will only move about three inches then acts like it is bottomed out
tn terry t
03-08-2008 10:42:29
 Re: hows it work? in reply to Re: 460 is a knocking..., 03-07-2008 19:51:50
[img]third party image[/img]
Janicholson , Jim Becker I got it figured it out!!!!! this number 1 and number 2 had got fliped backwards some how now she go up and down all the way!!!!!
[size=18:43bcbef919][/size:43bcbef919]thank you guys so much!
tn terry t
03-08-2008 08:53:38
 Re: hows it work? in reply to tn terry t, 03-07-2008 19:51:50
[quote="Janicholson"](reply to post at 03:29:31 03/09/08) [/quote
actually its a 230 Jim number 6,7and 8 seems to move ok number 3 thru 10 doesent move at all. the depthelimiting gauge slider is all the way to the top next to the clevis. the cylinder will close all the way down but will only raise about 3 1/2 inches then loads the engine . ill get it figured out . thanks to you guys giving me some insight as to how its supposed to work . right now i'm just piddling with it cause i've been out of work for 6 weeks with a rotator cuff repair. kinda one arming things right now lol in about 6 or 8 more weeks ill get back to work then maybe i can get serious working on this old dude [img]third party image[/img]
tn terry t
03-07-2008 21:16:30
thanks Mr Becker this old tractor has been sitting out in the weather for ever . that number 9 is all froze up i sprayed it down good wth lube and taped on it a little i guess im going to have to get a little ruffer with it maybe thats why the cylinder wont go up very much i dunno
Janicholson
03-08-2008 06:29:31
 Re: hows it work? in reply to tn terry t, 03-07-2008 21:16:30
I'll add to the great info from Mr. Becker. The mechanical traction Control was marginally successful. A first attempt. This one looks to be from a 350, 350U, or 450 series. The components will not limit the cylinder travel. The cylinder will bend these components (or break them free from rustiness) easily. So these will not be the cause of your grief. There is a depthelimiting gauge slider on the cylinder, and that only limits down depth. other than that I think it is a hydraulic issue, or non stock cylinder. JimN
Jim Becker
03-07-2008 20:57:39
That handle sets the sensitivity of the traction control. Equipment load pulls back on the lever at the bottom of #8, which causes forward movement of the lever on top of #8. Increaed load pulls forward on the rod #7. The rod pulls on the upper end of #9, working against a torsion bar. The extent that the upper end of #9 moves determines how much lift is applied at the cylinder to transfer weight from the implement onto the tractor tires. Moving the handle up raises the contact point of #7 on #9. The higher the contact point, the more leverage #7 has and the more the hitch will respond to the changes in load.
As far as how well it works, there have been 2 recent threads on that subject.
maplehillfrm
03-07-2008 22:14:50
 Re: hows it work? in reply to Jim Becker, 03-07-2008 20:57:39
well thank you for the detailed description, My neighbor has a 460, and we couldnt figure out what that was,, now I can tell him I know,, but it may cost him a cup of coffee,
tn terry t
03-07-2008 20:38:04
[img]third party image[/img][/list]
well maybe this will work
tn terry t
03-07-2008 20:21:27
Janicholson said: (quoted from post at 17:02:57 03/08/08) We have nothing to look at the link doesn't work (for me at least) which tractor which issue. JimN
hey buddy hw ya doing/ its a 230 the traction controll unit I cant seem to make the link come up for ya . Im trying to pull photo from the CNH site sorry
Scott Rukke
03-07-2008 20:11:28
Link doesn't work.
tn terry t
03-07-2008 20:04:50
should that number 9 and number 3 swivel some how?
Janicholson
03-07-2008 20:02:57
