Frame Rail Bolts
GordoSD
03-08-2008 06:45:33
File this under lessons learned. Ya'll know I'm at the last stage of completing an H. I had not removed the frame rails for blasting, filling and reinstall so I thought I'd mop that up today. NOT. Right side, front bolts came out with a little persuasion. Then the two through the engine mounts, both heads twisted off with about 25 lbs of torque. I have an advanced degree in metals, failure analysis, fracture and metal fatigue. Well the analysis of these two bolts shows a 75% corrosion, influenced by overstress fatigue,failure of the remainder under expected load. Rockwell hardness test showed Grade 3 or less bolts. Vibration of the engine likely causing fatigue. Once they began to crack, corrosion doomed the remainder. So they were just plain rusted almost completely through, cheap factory issue. Got one drilled out 29/64 and tapped 1/2 -20NC. After I go to town to get a new 29/64 bit I'll tackle the rest. So much for the good old dot head bolts! However, IF they can hold up under 100 lbs torque coming out, they ought to be good for 50 going in after running a tap in the support and a die around the bolt.
Gordo
Gauger
03-08-2008 15:33:15
 Re: Frame Rail Bolts in reply to GordoSD, 03-08-2008 06:45:33
I have an interesting situation with the frame rail to bolster bolts on my '54 SH. All 4 on each side are 9/16" NC and not dot head. The book calls for 1/2". The odd part is that the tractor did not appear to have ever been apart so I don't know why these bolts would have been replaced with larger ones. The tapped holes in the bolster are perfect, straight and no slop at all in the threads. ??
James Williams
03-08-2008 08:07:23
As far as grade of bolts,I dont know.But I always thought IH bolts were second to none,Ive restored 8 pre 39 tractors and I dont beleive Ive twisted of a dozen bolts all together
jimmy
scott rukke
03-08-2008 07:33:39
Half of my frame rail bolts broke off when I removed my F-20 rails. A couple had a cross sectional area of about 3/16". I'm glad I removed them because there wasn't much holding the old girl together. I didn't drill any of them though, I welded a nut over what was sticking out and they all screwed out. A couple came out with a pipe wrench. The nut seems to work good but you want it as close to the threaded end as possible.
RustyFarmall
03-08-2008 07:10:19
Very seldom do I put the original dot head bolt back in. I feel that after 50 or 60 years on the job, that bolt deserves to be retired and is probably no longer capable of performing up to par anyhow. I'd much rather see the head of an aftermarket bolt on an old tractor than to see an original bolt that is probably ready to give up the ghost.
gene bender
03-08-2008 07:09:52
You didnt say why you need the new drill bit
Janicholson
03-08-2008 07:01:35
Turn Dot Head look on some Alloy! (my position is that someone will take that fine tractor apart again and find nice parts, instead of a pencil thin cross section, JimN
GordoSD
03-08-2008 09:06:33
 Re: Frame Rail Bolts in reply to Janicholson, 03-08-2008 07:01:35
The frame rail bolts have a "heavy duty" head on them Much thicker than a standard 1/2 inch bolt. ANyone know a source for them?
Gordo
ScottyHOMEy
03-08-2008 09:39:31
 Re: Frame Rail Bolts in reply to GordoSD, 03-08-2008 09:06:33
Are these what you're looking for?
GordoSD
03-08-2008 19:22:43
 Re: Frame Rail Bolts in reply to ScottyHOMEy, 03-08-2008 09:39:31
Yeah, anyone want the other 42? Minimum order 50.
Gordo
