Middle 2 Compression Rings on Farmall M
1 Dollar
03-08-2008 10:47:32
third party image
I am re-installing rings on my Farmall M, and I am reusing the old rings. The two middle rings have a bevel on the inside, and I didn't pay attention when I took them off to see it it goes up or down in the ring groove.
If I had a cross-section, it would look like the picture, with the flat side obviously against the cylinder wall, bevel side in the piston. So which way does it go?
Thanks again
James Williams
03-08-2008 12:51:28
 Re: Middle 2 Compression Rings on Farmall M in reply to 1 Dollar, 03-08-2008 10:47:32
From what I remember the bevel goes up,You need to check with your ring co.
jimmy
Janicholson
03-08-2008 11:28:54
Bevel down.
this allows a tiny bit of twist on the way down. causing a scraping action. learned at Perfect Circle training, 1969. JimN
RAW in IA
03-08-2008 13:37:17
 Re: Middle 2 Compression Rings on Farmall M in reply to Janicholson, 03-08-2008 11:28:54
I think I remember tha bevek on the inside goes up. Letsthe compression help push ring out to seal better is what I was told years ago.
1 Dollar Joey H.
03-08-2008 11:36:06
That's what my "gut feeling" was. Not for any reason, just looked right.
Thanks for the help.
(I should have the engine block back from the machinist next week, if anybody is following this little project!)
Duner Wi
03-08-2008 12:04:25
 Re: Middle 2 Compression Rings on Farmall M in reply to 1 Dollar Joey H., 03-08-2008 11:36:06
I just went thru this on a non "M" and Hastings rings. From the Hastings website it said.
Dot or pip mark always goes up.
If no dot or pip. bevel goes up.
If no dot ,pip and not beveled, either side up.
Good luck!
1 Dollar Joey H.
03-08-2008 13:13:41
 Re: Middle 2 Compression Rings on Farmall M in reply to Duner Wi, 03-08-2008 12:04:25
I've got dots. Top one has . and the bottom one has .. (fittingly).
Thanks
