starter ring gear
ramtuff
03-09-2008 12:11:08
Does anyone know if the ring gear can be reversed on H farmall ? Need input. Thanks;
John W (OR)
03-11-2008 20:24:22
 Re: starter ring gear in reply to ramtuff, 03-09-2008 12:11:08
How does one go about reversing the ring gear. I put the fly wheel on my A that I'm working on. Looks like I should do it before I go any farther.
Hugh MacKay
03-12-2008 18:37:11
 Re: starter ring gear in reply to John W (OR), 03-11-2008 20:24:22
John: Flywheel on the engine as you have, heat the ring gear uniformly all the way around, don't need to get it red hot, but close. You should parhaps clean of the flywheel of any dirt or rust behind the gear before hand. Once you have the ring hot you should be able to remove it with heavy welding gloves. Quickly clean the flywheel, you may have to heat ring again uniformly, and put it right back, again with the gloves.
James Williams
03-09-2008 19:18:20
Ramstuf,I am working on a F14 and only one side of the ring gear has beem cut to help the bendix start in,However this is a 1937 model
tractorsam
03-09-2008 13:26:18
I've done A's and C's as well and had no trouble. tractorsam
ramtuff
03-09-2008 13:44:22
 Re: starter ring gear in reply to tractorsam, 03-09-2008 13:26:18
Thanks alot fellas,You people have been very helpful. Thanks Again;
Hugh MacKay
03-09-2008 12:27:24
rantuff: Yes all old letter serial Farmalls can have the ring gear flipped. I've personally done a Super A, H, 300 and 130.
LN
03-09-2008 12:13:54
I have been told that the ring gears are directional and can not be flipped
gene bender
03-09-2008 17:45:01
 Re: starter ring gear in reply to LN, 03-09-2008 12:13:54
You have been told wrong. Now that person that said that did he turn one around?
