IH B434 3 point hitch Questions
bad_bo_ti
03-09-2008 16:17:08
Sorry for the long post!! I had my 434 out the other day with a box blade on it and noticed I have a lot of sway when I raise it, It has chain adjusters on the side and I had them adjust to where they were tight while the blade was done but once I raised it they got slack in them. The tractor has a drawbar and the previous owner(s) mounted the bottom links on the drawbar (welded pins on). Is this the reason for my adjusters not staying tight or do I need some other kind of anti-sway device. I haven't used this tractor for anything else so I don't know if having the lower mounts moved out on the drawbar is going to help me any, Do they make longer arms for the bottom if I need the extra length or should I be ok. Thanks, For the help. Chris
FromJB2
03-10-2008 07:42:22
 Re: IH B434 3 point hitch Questions in reply to bad_bo_ti, 03-09-2008 16:17:08
Hi Chris, 434 should have brackets under the rear axles with 4 holes in them.
Email me at clarabrownlee@rogers.com and I will scan & email you picture & description from B414 Operator's Manual. B414 & 434 were basically same tractor just different sheet metal & better seat.
JimB
