Re: farmall h wont run
wellsy
03-09-2008 20:13:50
hey guys i got to working onthe h this weekend and i ended up puting new cap rotor and a set of plug wires i also put in points and a condeser in and it still won't run i took a old spark plug wire and cut a v in it and it seems that the spark just stops what is wrong now
riverbend
03-10-2008 16:07:06
 Re: farmall h wont run in reply to wellsy, 03-09-2008 20:13:50
Did it run before you tuned it up ? If so, start putting the old parts back in until it runs again. If not, check to see if you have power at the points and try posting back.
Greg
El Toro
03-10-2008 04:12:47
If you have a distributor you need battery voltage from the ignition switch to the coil. If it's a mag you need to make sure the mag's grounding switch isn't in the off position. Take a piece of 320 wet or dry and rub those new points. Make sure the plug wires are in this firing order on the cap. Hal
2-1
4-3
gene bender
03-10-2008 03:19:58
Have you checked does the rotor line up with the tower when it fires.
Brownie450
03-10-2008 02:24:20
Just thought---don't rule out the condenser---new ones can be bad--been there, done that.
Brownie450
03-10-2008 02:20:54
Chuck is correct at .013 for mag, & .020 for the distributor.
ihc49er#2
03-09-2008 20:59:35
isnt those specs. the other way around? dist. .013 mag .020 . make sure your plug wires are wire core not carbon.those automotive wires just dont cut it.
Chuck46
03-09-2008 20:33:37
Wellsy, Do you have battery distributer or magneto? The points should be set at .020 for a battery, .013 for a magneto. Plugs at .025. Is it timed right? Good luck, Chuck
wellsy
03-10-2008 05:11:16
 Re: farmall h wont run in reply to Chuck46, 03-09-2008 20:33:37
i have the vertical delco distibutoron this tractor i also checked the points and it was .20
