Splitting a farmall M
REDPOWER7120
03-11-2008 08:44:38
I need to split my M to put some new seals in it. I have never done this before and try to do all my work on my tractors by myself. Can anyone give me any tips on the best/easiest way to split my tractor without killing myself, or worse, ruining my tractor?
mkirsch
03-11-2008 18:41:54
 Re: Splitting a farmall M in reply to REDPOWER7120, 03-11-2008 08:44:38
Splitting stand can be as simple as two pieces of 4" or bigger heavy channel iron bolted to the frame for legs, and some cross-bracing. Rollers on the ends of those legs to allow you to move the front half back and forth are handy. The rear end can be blocked up with cribbing.
A smooth level concrete floor will make the job easy.
RichH
03-11-2008 18:32:11
Safest... find splitting stands for both front and rear. Next best splitting stand for front half and good rolling floor jack for rear half.
Eric in MN
03-11-2008 12:16:38
i split my farmall m because i have a heistler 9 speed it isnt really hard just watch what your doing and remember where all the parts go and be safe
Wayne from MN
03-11-2008 09:06:57
Which seals? The olny ones you need to split the tractor to replace would be the main seal on the crankshaft. Transmission & belly pump drive seals can be done with minimal effort & no splitting.
