1944 farmall B
jerry jenkins
03-11-2008 13:45:36
please help I am looking for a block my is cracked thanks for any help....
John W (OR)
03-11-2008 20:06:47
 Re: 1944 farmall B in reply to jerry jenkins, 03-11-2008 13:45:36
There's one on e-bay right now $199 it from an A should work
ScottyHOMEy
03-11-2008 13:49:26
How badly is it cracked and where?
Dave_Id
03-11-2008 15:12:17
 Re: 1944 farmall B in reply to ScottyHOMEy, 03-11-2008 13:49:26
If it's just cracked on the left side behind the carb, that can be repaired, but if the cracks go accross the tops of the cylinders, then the best thing to do is junk the block.
jerry jenkins
03-12-2008 05:33:45
 Re: 1944 farmall B in reply to Dave_Id, 03-11-2008 15:12:17
thanks mr dave it is craked behind carb i live in south ga do you know any shops that can fix it. thanks ..
ScottyHOMEy
03-12-2008 07:09:36
 Re: 1944 farmall B in reply to jerry jenkins, 03-12-2008 05:33:45
Jerry, if yours is like most in that location, the crack will only be an inch or two long. Many folks have had success with cleaning it out REAL WELL, inside and out, and filling it with JB weld or a good epoxy. The B's cooling system isn't pressurized, so you just need something that will bind to the iron and hold the coolant in.
