Alternator issue
H fanatic
03-11-2008 17:36:56
Hey,
I have a 1946 farmall H and I was wondering how can you mount an alternator under the hood without modifying it. I tried putting it where the gen was mounted (using the same bracket) But the hood won't fit right. Is there another way to mount the alternator?
Thanks,
Nick
Brownie450
03-12-2008 03:43:32
 Re: Alternator issue in reply to H fanatic, 03-11-2008 17:36:56
Use 3/8 threaded rod for mounting the alternator to the bracket. I remember that we turned the mounting bracket upside down & had to lengthen the mounting holes about1/2 inch to get the proper belt alignment. We just used a hacksaw blade in the sabre-saw for making the holes longer. For the tightener-- use 2 pieces of 1/4 or3/8 inch thick by 3/4 inch wide steel slightly longer than needed & drill holes in both ends of both pieces[5/16 is large enough] & bend an off-set in one piece the thickness of the material[1/4 or3/8] to make the 2 pieces "flat" when bolted together. Use these bolted pieces like a hinged "V" to tighten the belt. I think we went to a 37 1/2 inch belt, also.
1953 Super M
03-12-2008 01:50:32
I have the alternator on the Super M and used the bracket from Brillman--GREAT product!
http://www.brillman.com/
460anger
03-11-2008 18:56:01
where do you find them are they a one wire or do you have to do some wireing thanks
wh
03-11-2008 18:55:49
 Re: EASY in reply to H fanatic, 03-11-2008 17:36:56
use a "idler pulley". makes it very easy to keep your belt adjusted. use the link and scroll down the pictures. alternator install is toward the bottom. i made the idler useing a pulley for a lawnmower deck.
F-Dean
03-11-2008 18:14:41
On an M you can just flip the bracket and mount the Hitachi Alternator without changing the belt. It may work on a H also.
See the archives for my (and Big John's) detailed instructions.
IH2444
03-11-2008 18:07:19
Use one of the little Hithachi alternators.
