DEGREEING CAM
LIVIN LUCKY
03-12-2008 03:39:32
I HAD A CAM CUT FOR MY M AND WAS TOLD TO SET THE DEGREE ON IT MY ? IS WHEN U BOLT IT IN LINE UP THE DOTS THERE IS NO MOVEMENT FOR IT. SO WHERE IS THE SETTING ON IT
Janicholson
03-12-2008 06:12:24
 Re: DEGREEING CAM in reply to LIVIN LUCKY, 03-12-2008 03:39:32
There are two methods I can think of. One is to use a special offset key in the drive custom made to place the desired advance/retard timing, the other is to use an adjustable drive pulley with a seperate hub and degree markings (unlikely to be available). If you have the specs for the cam, and a degree wheel for the front pulley, and a set of precision measuring tools, particularly a dial indicator, you can at least check the timing of the cam with all parts stock, and aligned as factory. If it is not reasonably close to the spec, (1/2 deegree)it will need adjustment to be powerful. JimN
Red Mist
03-12-2008 03:50:13
 NOT MUCH HELP in reply to LIVIN LUCKY, 03-12-2008 03:39:32
First, ask the fellow who made the cam for you. If he doesn't know of another way, then I'd say you've got to mis-align the dots to retard or advance the cam. mike
