H carb
GordoSD
03-12-2008 06:53:55
Will the H carb work on a 300U?
Gordo
Andrew Z
03-12-2008 07:45:22
 Re: H carb in reply to GordoSD, 03-12-2008 06:53:55
Also if it works youll have to change the throttle rod from the gov. to the carb. youll have to use the H part here to along with the carb. (the 300 one will be to short to reach the H carb)
Andrew
rustyfarmall
03-12-2008 07:58:36
 Re: H carb in reply to Andrew Z, 03-12-2008 07:45:22
Andrew Z said: (quoted from post at 07:45:22 03/12/08) Also if it works youll have to change the throttle rod from the gov. to the carb. youll have to use the H part here to along with the carb. (the 300 one will be to short to reach the H carb)
Andrew
No. The governor tubes are specific to each tractor. The tube length on the M through 450 will be longer due to the increased length of the engine.
The tube used on the H through 350 is shorter, because of the shorter engine length.
You can put an M carb on an H or a 300 and still use the governor tube that is currently on the tractor.
Andrew Z
03-12-2008 08:15:57
 Re: H carb in reply to rustyfarmall, 03-12-2008 07:58:36
My Falut i just measured mine and there almost the same, this is adjusted to how much of the throttle sahft that is in the gov. its a 3/8 - 1/4"
Also was thinking that if he has a new type manifold on the 300 then it was made to fit H-350 so any of those carbs will bolt to the manifold. if he still has the factory one on there i dont know if they had such large slots in the them for mounting the carb.
Sorry for confusion there
Andrew
RustyFarmall
03-12-2008 07:39:18
Don't think so. Mounting bolt holes are closer on an H than on the 300. An M carburetor WILL work, but the choke lever will be on the wrong side, but you can deal with that.
Janicholson
03-12-2008 07:03:56
I believe it will, but it is a bit different. And may be jetted a bit differently. How is the electrical Issue? JimN
GordoSD
03-12-2008 08:21:02
 Re: H carb in reply to Janicholson, 03-12-2008 07:03:56
Spent 2 hours on the 966 Monday, and 2 yesterday. It's working just fine. I need to check all the gages, lights etc and see what they do when it is working right, so I might see the problem when the gremlins return.
GW
