Super M Clutch
Smith1000
03-12-2008 18:04:59
I dropped the metal clutch housing cover on the M tonight to look at the clutch. It seems to be slipping and needs a new clutch. Oil and water ran out--mostly water. Kind of had a green tint to it like anti freeze may be mixed in. Would this be a bad seal or two?
From what I understand, the tractor must be split to replace the clutch as it has a 12 inch clutch.
rustyfarmall
03-13-2008 05:33:17
 Re: Super M Clutch in reply to Smith1000, 03-12-2008 18:04:59
I don't have any plans, but I have pictures of the stands that I built. I'll see if I can drag them in here.
[img]third party image
third party image
third party image
third party image[/img]
Smith1000
03-13-2008 15:32:30
 Re: Super M Clutch in reply to rustyfarmall, 03-13-2008 05:33:17
Those are perfect! Thanks for the photos. I may be able to come up with something that will work. They key is being able to roll the rear back.
rustyfarmall said: (quoted from post at 05:33:17 03/13/08) I don't have any plans, but I have pictures of the stands that I built. I'll see if I can drag them in here.
third party image
third party image
Smith1000
03-13-2008 03:35:21
Thanks. It definitely needs to come apart. There is no telling when the clutch was last replaced. I have had the tractor close to 20 years, so it may have been in there 30 years or more.
I"ll get started on it very soon now that it is warming up some outside.
I wonder if anyone has some plans for making homeade splitting stands.
Janicholson
03-12-2008 18:15:33
Green Water would be coolant. There are Core plugs in that region that could be leaking. there are no seals that could leak coolant. Cracks could (but we are not discussing cracks).
The tractor does need to be split. JimN
