Touch control oil?
comtcwby
03-13-2008 09:38:18
What type of fluids is everyone using to replace on their touch control units. The manual says to use touch control fluid by IH. Do they even sell such a thing? My Cub is all armstrong hyd. But my dad's Super A has the Hyd system and I am sure that it is way over due for a flushing and new fluids. I dont want to screw up the system. I know if you use Case fluids in some newer JD equipment, the system will heat up and shut down under heavy use. I dont remember my dad ever changing the control fluids. What is the best stuff to use?
Thanks for the info! Glen
Steven f/AZ
03-13-2008 16:15:48
 Re: Touch control oil? in reply to comtcwby, 03-13-2008 09:38:18
Jim is correct, Hy-Tran or equivalent transmission/hydrualic fluid works great.
Janicholson
03-13-2008 11:12:45
Hytran fluid is fine, As is JD hydraulic transmission oil. Brand name Hydraulic oil meeting Hytran, or JD spec will be fine. JimN
