400 Hydraulic Pump (again)
Paul in WI
03-13-2008 11:33:03
My Hydraulic Pump/system just stoped working. It is full of oil, tractor starts and runs with no noises that are out of the norm.
It has 3 remotes and all have stoped working. Per your answers i 1. checked screen-clean
2. full of oil
3. no pressure from pump at remote outlet
4. oil not moving inside of res tank
Can a pump just quit working and the tractor still runn normaly?
Any more ideas?
thanks
Paul
Arlen -MN.
03-14-2008 17:14:48
 Re: 400 Hydraulic Pump (again) in reply to Paul in WI, 03-13-2008 11:33:03
Well ,If you lose fluid from leaking conections, or other reasons,and run low of hyd. fluid you are going to lose your prime. Maybe it never happens to any of you , but it has to me.
Paul in WI
03-14-2008 08:49:39
 Re: 400 Hydraulic Pump (again) UPDATE!!! in reply to Paul in WI, 03-13-2008 11:33:03
First off. Thanks for all your help and input!!
Turns out that the pump lost prime. Not sure how or why.
Bottom line all is working again.
Thanks!!!
Paul
Jossette
03-14-2008 18:05:36
 Re: 400 Hydraulic Pump (again) UPDATE!!! in reply to Paul in WI, 03-14-2008 08:49:39
if it lost a prime, check the vent on top of reservoir to see if it plugged
Allan In NE
03-14-2008 09:05:29
Paul,
If it "lost prime", it's on it's way out anyway. I'd be for replacin' that thing.
Allan
Paul in WI
03-14-2008 09:24:33
 Re: 400 Hydraulic Pump (again) UPDATE!!! in reply to Allan In NE, 03-14-2008 09:05:29
You are reading my mind, what is left of it!
thanks.
Paul
Allan In NE
03-14-2008 03:55:08
Yes,
They are steel gears inside of an aluminum case; they wear and wobble out over time.
Sounds like ya need a pump.
Allan
Jim J
03-13-2008 17:01:55
An air leak on the suction will make the pump loss prime. Check for cracks and replace the o-rings
Janicholson
03-13-2008 15:56:08
There could be a pump failure internally that would allow the shaft to turn, but the gears to be stopped.
Pull off the steel piping and take a good light and see if you can see inside the pump to check motion.
At the least, you can pur a rubber hose in the intake hole, and another in the exhaust, and pump into and out of a bucket. The bucket should be about at the height of the pump while trying it. Priming might be needed by putting oil in the intake side hose before trying it. JimN
karl f
03-13-2008 15:50:56
what noises do you consider "normal?"
what does the plumbing look like? if you have a rubber hose in the suction line, the insides could have collapsed. maybe a relief valve quit? do you have factory powersteering? the flow divider could be unloading it all to the powersteering.
karl f
Paul in WI
03-13-2008 15:59:44
 Re: 400 Hydraulic Pump (again) in reply to karl f, 03-13-2008 15:50:56
normal, no grinding of loud noises coming from pump .
no factory PS
and using factory steel lines, all in good, no rust , shape
mkirsch
03-13-2008 11:55:48
Paul, in a word, no. The pump drives the distributor, so unless you have a diesel that you've somehow managed to convert to direct-start, the pump must be turning in order for the tractor to run.
I suppose it could have lost prime, but it doesn't lose prime for no reason. Have you tried priming the pump through the little fill hole on top of the pump? Fill it up with the tractor not running, then start it up and see what happens.
