piston preference
gab
03-14-2008 14:28:21
Was M+W considered a better piston than a Firecrater? I noticed a used set of each on Ebay for a 123 engine and the M+W set are going for about four times more in a couple days less time. Jim
the tractor vet
03-14-2008 19:49:38
 Re: piston preference in reply to gab, 03-14-2008 14:28:21
From what i have seen over the years that the M&W flat tops may not give the total Hp. as a step head but when ya got down to the nitty gritty of bottom end torque the flt tops would lug far better . Now if ya really want to get the max out of a Farmall engine then install the high alt. pistons and do a few other trick things and they will come to life big time.
Jake Winn
03-15-2008 08:40:24
 Re: piston preference in reply to the tractor vet, 03-14-2008 19:49:38
Are you talking about the IH high altitude pistons? I have a set of 8000 ft pistons for my H. What other tricks can i do to kick it up a bit? Thanks Jake
the tractor vet
03-15-2008 18:12:33
 Re: piston preference in reply to Jake Winn, 03-15-2008 08:40:24
On your H a 350 cam intake carb head and dist. if yours has not been up graded as there was a advance change that cut total advance timing back and hold it around 27-29 degrees and this will realy help on the bottom end pull.
randy hall
03-14-2008 16:14:35
i prefer m+w pistons . the firecraters would be my second choice, and i am even a dealer for new firecrater piston sets. i have been farming with these old tractors for thirtyfive years.
