rims for a Farmall Super AV..
Jesse
03-15-2008 11:25:58
Can you guys tell me what the factory front rims would look like for this tractor. So far I have seen 2 different kinds..I just wondered what you guys have seen in the way of rims. I have seen those like the one in the photo section, but I have also since AVs with what I guess would be 16s like you see on an MV. Is there a "correct" style?
Dave H (MI)
03-15-2008 18:15:06
 Re: rims for a Farmall Super AV.. in reply to Jesse, 03-15-2008 11:25:58
OK....I had to go look it up. The AV (and I am assuming since I found nothing to the contrary) the SAV had 3x19 rims. There were little tabs on the rims to attach them to the standard wheel to allow for the larger rim. Standard A/AV would appear to have had 3 x 15 rims. Excellent picture on page 25 of the book...you should really order a copy.
Dave H (MI)
03-15-2008 11:30:18
Guy Fay's (hope I spelled that right!) book on letter series is hard to beat for what you want to know. Pics are heavy into hi-crops and there is a section for each part of the tractor that will tell you what was original equipment. I can recommend this book which I found under the tree in December.
