H farmall carb.
Eddie Jones
03-15-2008 16:33:34
Have a freind that clean and rebuilt the carb. on his H farmall. But when he went to start it it ran wide open. Moving the throttle lever had no effect. He took it off and re- assembly it it started up and Idle but when he move the throttle lever it ran wide open again. Moving the throttle lever had no effect when he try to pull back the throttle. What should I check or do when I look at it? Thanks Eddie
CNKS
03-15-2008 17:41:47
 Re: H farmall carb. in reply to Eddie Jones, 03-15-2008 16:33:34
Unless he did the world's worst repair job, Dave is correct.
Dave S.
03-15-2008 16:48:20
Check the connection between the carburetor throttle shaft and the shaft coming from the governor. The square peg on the end of the governor shaft should be in the slot on the carburetor shaft
