Fast Hitch for Farmall C
SDP1
03-16-2008 05:07:03
I recently bought a fast hitch for my Farmall C and it seems that the pulley is in the way of the mounting bracket on the right side. Do I have to remove the pulley and the shaft or can I get around this?
don g
03-17-2008 06:39:23
 Re: Fast Hitch for Farmall C in reply to SDP1, 03-16-2008 05:07:03
here ya go with a pic
I.H. parking only
03-16-2008 08:44:20
I just put a fh on my super c, the pulley is not in the way of anything except when you raise the hitch all the way.
gene bender
03-16-2008 07:16:54
Just remove the cap screw and the pulley will slide off as its in the way when the hitch is raised.
SDP1
03-17-2008 07:17:43
 Re: Fast Hitch for Farmall C in reply to gene bender, 03-16-2008 07:16:54
Beautiful! If you have any more shots of the full system, it would really help since I still don't know where the bracket with the four holes goes. Thanks a million.
Wayne in MN
03-16-2008 06:03:23
third party image
I have a Fast-Hitch and pulley drive on my SC; Not sure if you need to remove the drive to instal the hitch or not.
SDP1
03-16-2008 07:05:52
 Re: Fast Hitch for Farmall C in reply to Wayne in MN, 03-16-2008 06:03:23
Could you post a rear view of your super C so I can see what it should look like all fitted up?
thanks
Wayne in MN
03-16-2008 14:54:04
 Re: Fast Hitch for Farmall C in reply to SDP1, 03-16-2008 07:05:52
This picture was about 15 years ago; don't think I have a rear view.
