Clutch release sleeve guide
P and R Pete
03-16-2008 14:52:05
On my Super-A, I'm cleaning up prior to getting a new TO bearing in.
I want to re-grease inside the clutch release sleeve guide. The crud in there is real sticky. Is it a press fit into the torque tube? I don't want to work it out if I can't get it solidly reseated where it won't come loose.
gene bender
03-16-2008 15:16:40
 Re: Clutch release sleeve guide in reply to P and R Pete, 03-16-2008 14:52:05
Yes it is a press fit make sure the grease zerk is lines up so you can reach it thru the hole in the bellhousing and clean the carrier so grease can get thru the hole so when the to bearing is greased the tube also gets some.
P and R Pete
03-16-2008 15:05:20
Here's a pic-
third party image
Red Dave
03-16-2008 16:59:25
 Re: Clutch release sleeve guide in reply to P and R Pete, 03-16-2008 15:05:20
If the sleeve in the picture is the one you are talking about, I'd let well enough alone. It doesn't need grease. When everything is back together and lined up, the shaft runs in the center of it without contact against the sidewalls.
It has a little grease in it now because of some grease migrating back from the throwout bearing.
P and R Pete
03-16-2008 17:06:23
 Re: Clutch release sleeve guide in reply to Red Dave, 03-16-2008 16:59:25
Sounds good. I don't have the equipment to press it back in anyway. I can work a little grease in with my fingers. That should suffice.
Thanks, you guys.
