International farmall H
hsojman
03-16-2008 16:45:52
what should the oil pressure for my tractor be? When it is warm it is about 25? is that ok?
Steven f/AZ
03-17-2008 05:42:55
 Re: International farmall H in reply to hsojman, 03-16-2008 16:45:52
Spec for a new engine (relief valve pressure) is 75 psi. My rebuilt H will peg the gauge all day long and come down to around 50 psi at idle, hot.
As long as you have around 20 psi at full throttle you are doing just fine. I've seen many of them run for many years with even less than 20 psi and no problems.
CNKS
03-16-2008 19:14:35
Probably ok, could be the oil pump, your bearings are likely worn. "New" oil pressure is about twice that, or more.
Pat-CT
03-16-2008 18:51:48
i dont know but mines just under 75 like 72 ish mine just pegged itself to one side when i put a 25 psi guage on it
Pat-CT
03-16-2008 18:51:38
Pat-CT
03-16-2008 18:51:28
Pat-CT
03-16-2008 18:51:19
Pat-CT
03-16-2008 18:51:11
tn terry t
03-16-2008 17:35:11
 Re: International farmall H in reply to Red Mist, 03-16-2008 16:45:52
old i dont mean to hi-jack this post but ive got a question about the same thing .
my 49 has 70 psi on two different gauges anf when hot drops to about 55to 60 is something with the releif valve or something ?
CNKS
03-16-2008 19:12:43
 Re: International farmall H in reply to tn terry t, 03-16-2008 17:35:11
It's normal, all oil pressure drops some when hot.
old
03-16-2008 17:00:22
25 psi is real good for an old tractor like an H
