Brake cover Alan in neb
HENRY E NC
03-16-2008 18:50:08
I have done my brakes on mu M and I cannot get the cover back on. It seems really stupid as I have had it off before no problem. Alan would you please repost your picture showing the brake band before you put the cover back on? Can't get it from archives. Somehow something is not right. Thanks, Henry
Allan In NE
03-17-2008 05:50:38
 Re: Brake cover Alan in neb in reply to HENRY E NC, 03-16-2008 18:50:08
Here ya go, Pard.
Allan
third party image
rustyfarmall
03-17-2008 04:25:18
Do your covers have the adjustment bolt at the bottom? You might need to back it out a little.
Michael Soldan
03-16-2008 19:30:06
There is a hole in the trans case that the activating lever fits into when the pan is installed. It has a brass bushing in it. Make sure this is clean and has some lubricant, grease or white grease or anti sieze. That would be the only thing that would keep the brake pan from going on...other than the brake band not going over the drum. I think the band can only go in one way and the pin put throught it. Look at the pan and move the activating lever with your hand..does the band tighten the same in both pans? Does the lever return the band wide open?That'd be a start..good luck
