How to Add live hydraulic pump to1951 wd9 - for 3 point.
tmb3203
03-16-2008 22:26:30
third party image
I want to add a live hydraulic pump farmall wd9 tractor. It appears I can pull the distributor (adapter) and add a pump in its place and remount the distributor? If so does anyone know the P/N of the pump or what tractors share the same pump?
Steven f/AZ
03-17-2008 08:07:43
 Re: How to Add live hydraulic pump to1951 wd9 - for 3 point. in reply to tmb3203, 03-16-2008 22:26:30
Cheapest way to go on a W-series tractor would be a shaft straight through the front bolster to a pump. Took a Char-Lynn set up off a WD9 a few years back, should have taken pictures...
Pretty easy to make a mount with those 4 bolt holes right up there, simple sleeve over the crankshaft with a pin through it and a shaft/sleeve to the pump. Could probably set it all up for around $250, depending on how big of a pump you need.
glennster
03-17-2008 06:57:04
the hydraulic pump is i h part number 355 554 r91 they are the same for the gas and diesel. according to my parts book, the pesco part number for the pump is 052168-020-01. you will also need the flange to connect pump to hydraulic lines, part number 355 556 r1.
mtdan
03-17-2008 06:47:10
All Diesels and W9 gas Are CCW rotation... been there..there are different mounting patterns though..M for sure is different. make a pattern of bolt spacing and look around found one at a wreaking yard all ready off of tractor.. not sure what it is off of..
Roger in Iowa
03-17-2008 06:35:25
My WR-9 has a pump and system added from a 600 or 650 gasser. Perhaps you can add one from a 600 or 650 diesel. A complete system contains reservoir, valves, outlets, pump and possibly useable hoses. Pressure may be only in the 1500 psi range. I don't know for sure.
You do have to watch rotation of pump!
Roger in Iowa
Janicholson
03-17-2008 06:12:24
The pump is rare and unique to Diesels in the IH/farmall line. I do not think there have been any aftermarket pumps made, but I could be wrong.
The pump is opposite rotation. Check the caseih.com parts listing for possible matches. Ebay, and bone yards might be two places to find one. Steven f/AZ has put belt driven pumps on successfully, and there are pictures he has posted. JimN
Armand Tatro
03-17-2008 03:10:58
I would like to see a picture of the 3pt hitch when you get it mounted. Thankyou. Armand
Gary,kansas
03-16-2008 23:02:12
Check with your dealer or have patience, but that probably is a 300 or 400 pump. If you check back a couple of days you will find a discussion of installation on an H which might help. Patience will get you many answers from the fine folks on this site.
TractormanNC
03-17-2008 05:17:16
 Re: How to Add live hydraulic pump to1951 wd9 - for 3 point. in reply to Gary,kansas, 03-16-2008 23:02:12
Pump from a 300 will NOT work, too small. I dunno about a 400 pump. Be aware that pump rotation is opposite on a MD and 400D from the gas ones, think the WD9 is opposite of the W9 also.
