Farmall H Hydraulic Drain Plug
rlk
03-17-2008 07:07:44
Can anyone tell me where the hydraulics fluid drain plug is on a Farmall H ? I looked all over for mine this afternoon and have not found it. (I know it is not hydraulic fluid, but motor oil.)
Thanks, Bob
rlk
03-17-2008 12:35:04
 Re: Farmall H Hydraulic Drain Plug in reply to Armand Tatro, 03-17-2008 07:07:44
Thanks Don, Steven, Scott & Dave. I finally found mine. The plug was rounded off, and did not look like a drain to me.
Bob
Steven f/AZ
03-17-2008 08:10:24
 Re: Farmall H Hydraulic Drain Plug in reply to rlk, 03-17-2008 07:07:44
There is a 90 degree elbow and hose screwed into this one:
third party image
Don L C
03-17-2008 10:08:27
 Re: Farmall H Hydraulic Drain Plug in reply to Steven f/AZ, 03-17-2008 08:10:24
Some body used the drain hole for the return line for aditional hydraulics....they should have used a T and pipe plug....the original system uses 30w engine oil.....
scott rukke
03-17-2008 08:00:21
In addition, the return line is sometimes ran to the drain plug hole. Hopefully if they did this they used a tee fitting to allow you to still drain the fluid without taking the hose off.
Dave S.
03-17-2008 07:57:57
Looking at it from the back side it is on the bottom of the pump left side. Usually a pipe plug with square head
