Little Genius Plow
Tim Plude
03-17-2008 11:48:38
I have a Little Genius plow on rubber that I pulled out of the woods last winter. One of the front rims was rusted through, but I found a replacement for that. The problem that I have is that the rear wheel rim is also rusted through. Would anyone know where I could get a new one, it has a large center hole, and a 3 - bolt pattern. Any help would be greatly appreciated.
John S-B
03-17-2008 20:42:04
 Re: Little Genius Plow in reply to Tim Plude, 03-17-2008 11:48:38
You may be able to fit one of the older metal rear wheels on it, I think the ones one the old hay rakes were the same as the plows.
wildman from mo
03-17-2008 14:51:01
I have serveral of these plows all in different conditions,when you start messing with things that are 60 years old you better get out the torch. Cut out the center,drill three holes in the new steel and weld it in.If the wheel edge is thin take a 3/8's rod weld it to it bend it around as you go.Cost $5.00 and couple hour's of your time . Good luck Wildman
James Williams
03-17-2008 14:45:22
Tim,I repaired one a couple years ago.I found a rear wheel that had a bad rim.Cut the rim loose fron the wheel,I think it was held by rivets,cleaned it up good and pressed it inside of a new rim,I think it was one from either a C or H front,it fit with a snug fit and plug welded together
jimmy
Dave S.
03-17-2008 12:27:41
Tim a good rim off of a plow is hard to find around my neck of the woods. I had to buy a wheel (tail wheel off of a IH mower I think), cut the center out of both of them and weld the center for the plow in the mower rim.
Bought the tail wheel from: Stauffer salvage 785-966-2739 Dave
Rocky Carr
03-17-2008 12:20:46
I recently purchased some hitch parts from Pat K who frequents this board. He was very helpful and indicated he had other plow parts as well. Here is his email address teegardenfarms@yahoo.com Miller tire sells the angle tread tire for the rear wheel, pricey $80 but the only place I have found one for sale.Good luck with the plow. Someday soon I hope to be able to share pictures of mine after the restoration.
Rocky in MO
