brake screw Rusty Farmall
HENRY E NC
03-17-2008 14:29:11
It was the brake adjustment screw . a whole days work (4 hours) just because I thought the adjustment screw was backed out enuff. Had to take it out and then, slick as a pigs whistle it all fit. The end of the screw was just barely peeking out and caught the brake lining . Stupid is as stupid does. At least my dad got smarter as he got older. Not much hope for me. Henry
rustyfarmall
03-17-2008 16:53:49
 Re: brake screw Rusty Farmall in reply to HENRY E NC, 03-17-2008 14:29:11
Lucky guess on my part. Makes a guy feel good though when everything finally comes together.
Wayne in MN
03-17-2008 16:46:27
After installing the brakes, apply them fully, lock the pedal, and tighten the adjusting screw snugly. Back out 1/2 turn and lock the nut. This positions the brake so it doesn't drag on top and allows for more accurate adjustment at the pedal.
James Williams
03-17-2008 14:35:15
Henery,if what you say is true than me and you are the dumbest around
jimmy
