M brake drum wobbles????
mike a
03-17-2008 17:25:41
Removed right side brake band today and noticed the drum will move in and out approx 1/4 inch. But what bothers me even more is that if you grab both sides of the drum and check for brg looseness,it moves a good bit that way too. This ain't normal is it?? Tractor acts like it doesn't have mvery many hrs on it as steering and trans shifter are super tight. trans and rear are also very quiet.Whatta think??? DOPE!!- should have told you its a straight non-super M
mike a
03-18-2008 13:47:17
 Re: M brake drum wobbles???? river in reply to mike a, 03-17-2008 17:25:41
How-pray tell???
riverbend
03-17-2008 18:07:55
 Re: M brake drum wobbles???? in reply to mike a, 03-17-2008 17:25:41
Why did you remove the brake band ?
The wobble might be as simple as the bolt that holds the brake drum is loose. Or as complicated as a busted differential housing ( ask me how I know...).
Greg
