706 pinion bearing,
farm-al
03-17-2008 20:00:52
I have a farmall 706 that broke the flange off the bearing cage housing, I find that a new style bearing and housing is offered with a new ring gear and pinion set, any one had any experiece with these new style parts, will the new style bearing and housing work on an old style ring gear and pinion? My R.& P. can be reused, all I really need is the brg. housing, thanks for any help,Al
the tractor vet
03-18-2008 07:26:49
 Re: 706 pinion bearing, in reply to farm-al, 03-17-2008 20:00:52
IF it was me i would be looking for a used bearing cage then come the set up of the ring and pinion and bearing preload . As for the new style i have never in all the 06 seires tractors had to replace one so here i do not know . I have had to replace pinion bearings and a couple ring and pinions over the time that i worked on them but never got a new set up . Luckly i have the special tools to do this . IT also helps to get the parts out of a parts tractor along with the shims .
