560- Water in hytran
BrianDuluth
03-18-2008 14:50:13
Had water in hytran-cleaned,flushed,refilled, then siliconed bolts on transmission access cover.Still getting water in. It freezes in winter and creates problems BIG problems. Other than shedding the unit, is there anything I can do???
Lee in Iowa
03-18-2008 19:47:02
 Re: 560- Water in hytran in reply to BrianDuluth, 03-18-2008 14:50:13
My 560 sits inside almost all of the time and it still gets water in the hytran it must be condensation. Don't know what to do about it. Lee
Hugh MacKay
03-18-2008 16:06:46
Brian: Most of the water runs down the gear shift lever right into the transmission. I took a section of very heavy inner tube, about 6" x 8", cut small hole in middle, slid it down over shift lever right to the spring, then used a glue around the inner tube and shaft. Let the tube ends hang down over the tower to run the water off. Some have lasted one season, and I have one that has lasted 10 years. Not perfect, but it helps.
I've seen guys use a long plastic sleeve, length of shift lever, right down to the base. It works well. With short gear shift levers like SA, I just put a plastic bucket over the shift lever. That shift lever catches a lot of water and the longer they are, the more they catch.
