1680 Combine
Tom Bateson
03-19-2008 08:46:15
During the last four months, I have ask for and received some great advice and help repairing this 1680 combine. Everthing from the rear main engine seal, through the grain table and augers and most recently the feeder housing. A big THANK YOU to all who respoded. Now I have one last question (I hope). The unloading auger does not always swing out when using the hydraulics. Sometimes, it requires a shove to get it moving away from the combine. I am guessing that there may be some dirt in a check valve or pressure relief valve. Has anyone encountered this problem and if so what did you find? Again, Thanks for all the great help.
ejr-IA
03-19-2008 09:42:00
 Re: 1680 Combine in reply to Tom Bateson, 03-19-2008 08:46:15
Maybe you need to tighten up the support rods to take some weight off the rear support saddle or adjust the saddle down a little.Sometimes I'd have to rev up the engine a little to get it to swing.
i luv farmalls
03-19-2008 09:20:37
grease the pivoting elbow and swing it in and out a few times, then grease it again to get the dirt out.
thats what I had to do on my 1440.
