140 timing
farmall boy
03-20-2008 12:55:34
how should the timeing marks look on a 140 enigne. should they be like . . or . . . thanks
El Toro
03-20-2008 14:22:09
 Re: 140 timing in reply to farmall boy, 03-20-2008 12:55:34
third party image
I think they should be aligned this way when the keyway on the timing gear is on your left as you face it. Hal
PS: Read the typing on the edge of the sketch.
farmall boy
03-20-2008 13:08:05
sorry it was suppose to look like two dots with a single dot in the middle or two sinle dots lined up
El Toro
03-21-2008 05:14:10
 Re: 140 timing in reply to farmall boy, 03-20-2008 13:08:05
You need to align the single punch marks on the
camgear with the single punch marks on the crankshaft gear. Then align the double punch marks on the camgear with with single punch mark
on the governor gear. Hal
