How bad is this
Pat-CT
03-20-2008 13:19:23
i drained the oil out of my h's rear end again and i found some metal shardes in there i looked in with a flash light and saw a hole the size of an apple in the front most wall which is pretty thin but now the H leeks oil fast around hydraulic pump shaft that comes out of the rearend so how bad is this can i jsut put rtv around that and see if it helps theres no whole stright threw but it does go into like a second wall or somekind of area so how bad is this ive used it sence with no problems except for the oil leaking
Owen Aaland
03-21-2008 12:46:05
 Re: How bad is this in reply to Pat-CT, 03-20-2008 13:19:23
The transmission counter shaft can be held by engaging the PTO and using a pipe wrench on the output shaft.
neblinc
03-21-2008 07:54:45
Pat, take a look at my web site for lots of pics on my H tear down.
There are about 8 pages of pics that should help you.
H Pics
Randy
Tom Bateson
03-20-2008 14:33:52
I made a socket by welding a piece of steel key stock inside a 3/4" Drive socket and then turn it off with the impact. It is a tight fit so I had to make the socket very shallow. This does require remvoval of the belly pump though.
Pat-CT
03-20-2008 14:28:07
how does it come off its meant to pin i jsut put it in the little notch there and spin
John M
03-20-2008 13:59:43
It screws on, normal thread. Lock your brakes, and put it in gear, chock the wheels if you want.Use whatever method you wish to get it off, I persoannly have used a square peice of stock and a hammer, a pipe wrench, and/or a combination of them all.
Pat-CT
03-20-2008 13:41:41
nah im not getting a new H there to expensive here like 1800 is cheap its not a hole in the actual case but a wall i dont think its a big problem Now how do i get that drive coupling out third party image
i taking the bolts out and it wouldnt budge i tried spining the inside and it just moved the tractor with it in gear no luck am i missing something?
Red Mist
03-20-2008 13:31:31
Pat: A hole the size of an apple? Holy Toledo! That will take more than some rtv. I would say junk out that H and get another one. H's are very, very cheap. You can keep the one you have now for parts. By the time you by a good casting and switch everything over, it will be 6 of one and half dozen of another...
mike durhan
Janicholson
03-20-2008 13:31:07
The oil is common between the two areas. If it is leaking, it is the Hydraulic pump coupling drive (front of the countershaft in the trans) that is leaking. This can be replaced through the inspection cover (with the pump out) by taking the drive coupling out (housing drained) then removing the coupling (lefty loosy) with a hard steel square to turn it with (serious turning required). then it is obvious. JimN
Red Mist
03-20-2008 13:36:20
 Re: How bad is this in reply to Janicholson, 03-20-2008 13:31:07
Jim: Say, again, please. I want to learn this. I guess I did not conceptualize - or comprehend - the original problem. mike
Janicholson
03-20-2008 19:49:21
 Re: How bad is this in reply to Red Mist, 03-20-2008 13:36:20
From what I imagine he is looking at, the Wall between the trans and finals contains a hole allowing 90wt to go between the two (separate drains due to different lowest sections, common fill hole in deck) thus what he may perceives as a punched hole may be the normal cast hole. Either way it probably will not affect operation. THe seals just get old and leak. JimN
mkirsch
03-21-2008 05:17:13
 Re: How bad is this in reply to Janicholson, 03-20-2008 19:49:21
Yes, the "hole" is normal. It's rough because it's a casting, and there was no need to clean it up.
