M Tires
Allan In NE
03-20-2008 16:49:12
What would be the next size wider(and taller) than a 13.6 X 38?
Thanks
John17
03-22-2008 14:20:58
 Re: M Tires in reply to Allan In NE, 03-20-2008 16:49:12
Allan, the next size is 14.9x38. Of course they have changed that to metric, but you should still be able to find them in that size. How far are you from Kearney? There is a large dealer (Nebraska Tire) that has a warehouse out west of there, full of tractor tires. I do not have a telephone number for them, but I think they are on the 'net. HTH, JohnG
John M
03-21-2008 03:58:35
Allen, I havent bought tires in a few years now, but if youre putting them on your M, make sure you get 6 ply or better tire since you have that 3pt on there. One of my 41s has some original 4 plys, not origianl to the tractor, but original to a later model M. It use to squat those down pretty good even pumped up a little high. My 40 M, with the same 3pt I had on my 41, has newer 6 ply on it and with a 7ft "Bushhog", it still squats them, but not near as much.
Glenn F.
03-20-2008 20:37:42
I'd definately go 15.5's on 14" rims. The 15.5 and 13.6 are the same height, thus not effecting your gearing. 14.9's are designed for 12" rims, and a lot of M's have them, but 15.5's look sooooo oo much better.
Glenn F.
Don L C
03-20-2008 20:17:58
My M has 14.9 x 38'....really looks nice.....Don
Lee in Iowa
03-20-2008 20:16:39
14.9x38's are the next bigger but I don't know how common they are any more. 15.5x38s are a lot more common but I think to do it right you should have a wider rim than the original rims for the 13.6x38s. Lee
jhb
03-20-2008 20:07:28
It depends on the brand and construction. Generally I have found the 14.9X38 stands taller than a 15.5X38 but not always. I am always measuring used tires trying to find the tallest and widest for farm stock tractor pulling. No matter a 14.9 or 15.5 looks better on a 14 inch rim. Just my opinion.
Mike CA
03-20-2008 20:01:53
Allan In NE said: (quoted from post at 16:49:12 03/20/08) What would be the next size wider(and taller) than a 13.6 X 38?
Thanks
Too bad your tires are mismatched, or I'd call dibs!! :D
sd pete
03-20-2008 17:15:54
A 14.9 tire is taller and a 15.5 is wider but will have the same diameter.
HENRY E NC
03-20-2008 18:47:15
 Re: M Tires in reply to sd pete, 03-20-2008 17:15:54
and the 15.5's look so nice. Almost perfection for an M Henry
old
03-20-2008 17:04:46
14.9X38 would be the next size up and then 15.4X38 the next bigger
Dave_Id
03-20-2008 17:03:23
14.9x38
